Compensation of the saddle
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45695
Author:  aqualibguitars [ Mon May 11, 2015 10:39 am ]
Post subject:  Compensation of the saddle
Hello friends
im build new 650 mm scale length classical guitar on torres plan.
confused while compensating the bridge.
on treble side the scale length should be 650 and should on bass side the saddle should be compensated by 2 mm
i.e it should be 652 mm?
also for acoustic guitars i use 648 mm scale lenth.
so on treble side the scale length should be 648 and on bass side it should be 651 ( 3 mm of compensation) if im using straight saddle
and what to do on the compensated saddle?
my guitar bridge saddle slot is already compensated by 3 mm. so pls help me with measurements
for both straight saddle as well as compensated saddle
[:Y:]
Author:  Alain Lambert [ Mon May 11, 2015 8:30 pm ]
Post subject:  Re: Compensation of the saddle
For a 650 mm scale length, Cumpiano recommend a 0.10 inche compensation which is 2.54 mm for a straigth saddle.
So you saddle center should be at 652.54 mm, I think you are OK with your 3 mm.
Author:  aqualibguitars [ Mon May 11, 2015 11:50 pm ]
sir the saddle centre should be 652.54 mm or bass side?
and treble should be 650 mm?
can u explain me little?
Author:  Mark Mc [ Tue May 12, 2015 2:56 am ]
Compensation means that you are slightly increasing the effective length of the string to be greater than the "scale length" - this corrects for the effect of the change in path of the string when it is depressed to the fretboard. As Alain said, this means that for a 650mm scale length you actually place the saddle about 652mm or 653mm from the nut.
You have probably noticed that the saddle of a steel string guitar is slanted to provide a greater amount of compensation on the bass strings compared to the treble strings. This is necessary because of the big difference in string gauge between the bass and treble in a set of steel strings, and also the high string tension. However, in classical guitars, with nylon strings, it is usual to have the same amount of compensation for every string. Therefore, classical saddles are not slanted, they are at right angles to the path of the strings. So, you will want to have the saddle slot cut straight across the bridge, not slanted. Then the bridge position needs to be worked out so that the saddle is at scale length plus about 3mm (same for all strings). You shouldn't use a steel string style bridge, with a slanted saddle slot, to do a classical set-up.
You then check the intonation for each string. If it needs slight alteration you can change the shape of the saddle a bit to bring the break angle slightly forward or back on individual strings. If you are very clever you might compensate at the nut instead (look at examples by Trevor Gore or Nigel Forster), but most builders find that the standard set-up gets them close enough to the mark.
Mark
Author:  aqualibguitars [ Wed May 13, 2015 3:06 pm ]
Thanks friend for ur advice. will soon glue my bridge as u said
